<!--QuoteBegin-fanch+29.05.2004 à 16:43--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>
QUOTE (fanch @ 29.05.2004 à 16:43)</td></tr><tr><td id='QUOTE'><!--QuoteEBegin--><!--QuoteBegin-eliepower+29.05.2004 à 17:26--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>
QUOTE (eliepower @ 29.05.2004 à 17:26)</td></tr><tr><td id='QUOTE'><!--QuoteEBegin--> Fanch, If its EBC Green stuff pads you have, they are crap for cicuit use. You need at least Red stuff or Mintex 1166 alternatively you can mount Hawke pads they will not fade but they will eat disc's depending on how much track day you do but say about 1 pair a year. i have a set of sec. hand ( 1 trak day ) Hawke pads lying around with you can have for 30 zozo's
I am not sure you can have Pagid pads for the STD caliper, they are expencive but really the best at about 120£ for the Alcon or old style AP
Step 2 will be the brake fluid change to AP600 and if you then still suffer fade go for Castrol SRF brake fuid. <!--QuoteEnd--></td></tr></table><div class='postcolor'><!--QuoteEEnd-->
Thanks Elie
I have fitted EBC green stuff on my Cat <!--emo&
-->[img]http://www.forum-autoroule.com/html/emoticons/icon_redface.gif' border='0' style='vertical-align:middle' alt='icon_redface.gif' /><!--endemo--> : are these pads only for road use ?
I'll follow your advice <!--emo&
Fanch<!--QuoteEnd--></td></tr></table><div class='postcolor'><!--QuoteEEnd-->
<!--emo&
Fanch, je pense qu'avec des verts tu as assez !
Voir site :
http://www.ebcbrakes.com
Depuis que j'ai mes Alcon et mes plaquettes vertes (EBC) pas de problème...
Avant d'atteindre 650 °C en trackday ....avec nos seven de route....il faut le faire. <!--emo&
-->[img]http://www.forum-autoroule.com/html/emoticons/retard.gif' border='0' style='vertical-align:middle' alt='retard.gif' /><!--endemo-->
A moins de changer à chaque fois, des plaquettes route, des plaquettes circuit.... <!--emo&
Elie <!--emo&
-->[img]http://www.forum-autoroule.com/html/emoticons/coucou.gif' border='0' style='vertical-align:middle' alt='coucou.gif' /><!--endemo--> n'est pas d'accord avec moi sur ce point, mais à chacun sa théorie et sa pratique <!--emo&
depuis déjà 18 ans ... !
