Erratum Assembly Guide
Ici :
52 If a 7/16" hole is not visible, drill out the
six 5/32" rivets holding the top edge of the trim
panel surrounding this point and ease the trim
panel away from the chassis until the exact
location of the mounting boss is identified. Drill
a small pilot hole through the trim panel taking
great care not to touch the outer side skin and
enlarge such that a 7/16" bolt can be fitted
through, ensure that the inner thread in the
mounting boss is not damaged during this
process. Loosely fit bolt (1) and secure the trim
panel with rivets.
Ce n'est pas 6 rivets à retirer mais 14. C'est un détail mais ca peut toujours servir.
